Human Review Email Node missing "Ignore SSL Issues" options
Self-Signed certificated error when using Send ans Wait for Response Email node becuase no “Ignore SSL Issues” in node option, meanwhile the “Send an Email” node do exists
  • n8n version: 2.9.2
Hello @Norton_Wong - please share the workflows code - and any errors or screenshots to help us to assist you better.
Hi @Norton_Wong Welcome!
You can try mounting your self signed CA certificate into the n8n container at opt/custom-certificates and then try fixing the current permissions by:
docker exec --user 0 n8n chown -R 1000:1000 /opt/custom-certificates
the certificate should be in PEM format for it to get picked up, let me know if that works as this seems like an infrastructural issue rather then node issue.
