I am experiencing some issues while creating Api Credential to Facebook Trigger.
I had to uninstall and re install N8N several times due to after launching my localhost although the URL http://localhost:5678/ starts and informs server is running successfully, the web interface doesn’t work. http://localhost:5678/workflows and http://localhost:5678/credential are not available.
There was a problem init data: Request failed with status code 404
Due to uninstalling process, The error was in the first Facebook node.
127.0.0.1 - - [03/Dec/2024 16:56:48] “GET /rest/push?pushRef=mwpi8szufu HTTP/1.1” 404 -
127.0.0.1 - - [03/Dec/2024 16:56:57] “GET /rest/push?pushRef=mwpi8szufu HTTP/1.1” 404 -
127.0.0.1 - - [03/Dec/2024 16:57:07] “GET /rest/push?pushRef=mwpi8szufu HTTP/1.1” 404 -
127.0.0.1 - - [03/Dec/2024 17:01:39] “GET / HTTP/1.1” 200 -
127.0.0.1 - - [03/Dec/2024 17:18:35] “GET / HTTP/1.1” 200 -
127.0.0.1 - - [03/Dec/2024 17:19:53] “GET / HTTP/1.1” 200 -
127.0.0.1 - - [03/Dec/2024 17:19:53] “GET /favicon.ico HTTP/1.1” 404 -
127.0.0.1 - - [03/Dec/2024 17:26:49] “GET / HTTP/1.1” 200 -
127.0.0.1 - - [03/Dec/2024 17:29:59] “GET / HTTP/1.1” 200 -
- n8n version: Version: 1.69.2
- Database (default: SQLite): database.sqlite
- Running n8n via (Docker, npm, n8n cloud, desktop app): localhost
- **Operating system:**Windows 11
