I am facing the issue with converting from CSV node
Hi when I try to use convert from CSV file node I am facing some weird issue, my CSV files are UTF-16, I also tried with options to put UTF-8 but same results
Maybe try to enable this option and change to other encoding?
  • Exclude Byte Order Mark (BOM)
