Hello, I am new to this community and quite new to n8n. This is my first API project (connecting a database to Hubspot). Because I have created custom objects, I must use the HTTP Request node. The process begins with a Cron, then a HTTP Request to get the information (quite large), followed by a Function node to group entries (contact and contact data), then an Item List node (mainly for testing to limit the amount) and then the HTTP Request to post into Hubspot. At first I was receiving the error “ERROR: UNKNOWN ERROR - check the detailed error for more information…validation error…The request body may not be null.” So with the Body Parameters I tested one entry with all the properties. I got it to go through. So I attempted to put in a Body Parameter as I’d seen done here in the community: Insert Name, Add expression to value, click "Current Node, click "Input Data, but I did not have “options.” Instead it states [Data to large]. I followed another example by going to RAW parameters, click add expression next to Body parameter -. current node - input - JSON - options but an error appeared there as well. (I cannot recreate it at the moment to get the specific error). Let me know if any other information would be helpful. Thank you in advance for your assistance.
Here is the workflow:
The output for the last node is similar to a contact and their contact information (this is for a group but the same; so their name, address, etc).
Currently using the n8n desktop
