A few weeks ago there was a great thread here about silent failures — workflows that stop triggering, or run green and do nothing. I’ve been running automations for clients for years, and that exact pain made me build something for myself. After the discussion here (thanks pirateprentice, ASHIM, Aghassi, dima — that thread was the best design review this tool ever got), I cleaned it up properly and I’m opening it up.
FlowPulse — read-only monitoring for n8n, from the outside:
- Connects via the n8n API (URL + API key, ~2 minutes). Zero changes to your workflows — no heartbeat nodes, no error-workflow wiring, no per-workflow setup tax.
- Learns each workflow’s normal cadence and alerts when one goes quiet — including the case an in-workflow heartbeat can’t catch: the trigger that dies, so nothing runs at all.
- Classifies failures into real categories — expired OAuth ≠ API down ≠ rate limit ≠ your bug. On my own instance it turned a year of “465 errors, all unknown” into 16 distinct categories with the failing node named.
- One alert per incident, not one per failed execution — cooldowns, recovery detection, and re-alert on reoccurrence built in. Alert fatigue is how monitoring gets muted.
- Telegram + email. Dashboard with health per workflow, top failing nodes, error clusters.
What it doesn’t do (yet): it won’t catch “ran green but produced garbage” — output-baseline detection (“this slot normally produces 12, today 0”) is what I’m building next, and destination reconciliation (the fourth layer from the thread) is on the long-term map. If you need those today, the DIY patterns in that thread are the honest answer.
I’m looking for a handful of people who run n8n in production — especially for clients — to try it and tell me what’s wrong with it. Free, no card. I’d rather hear brutal feedback from people who live this than build in the dark.
