Sales teams miss RFP deadlines not because they’re disorganized, but because the RFP lands in a shared inbox, someone reads it, means to forward it, and it gets buried. By the time the right person sees it, you have 3 days left to write a proposal that needed 2 weeks.
Built a workflow that processes every RFP the moment it hits Gmail. The sales team knows about it within a minute, with all the key details already extracted.
What it does
RFP email arrives in Gmail → downloads the attachment → extracts all requirements and criteria → calculates deadline urgency → logs to RFP tracker sheet → alerts sales team on Slack
Takes about 15 seconds per document.
What gets extracted
Document details:
Issuing organization, project title, RFP/RFQ number
Submission deadline and submission method
Project scope summary
Requirements list:
Every requirement tagged as Required / Preferred / Optional with its category. The Code node counts each type separately so you know upfront how many mandatory items need addressing.
Evaluation criteria with weights:
Pulls each criterion and its percentage weight. Knowing the evaluation breakdown before you start writing changes how you allocate effort — no point spending 40% of your proposal on something worth 10% of the score.
Budget range:
Min and max budget if specified. Formatted as $50,000 - $150,000 or Up to $200,000.
Questions to answer:
Every specific question the RFP requires you to respond to, numbered and listed.
Qualifications and compliance requirements:
Certifications, licenses, and compliance standards required to even bid.
Deadline urgency calculation
The Code node parses the deadline date and calculates days remaining automatically:
OVERDUE — already past deadline
Urgent — 7 days or fewer
High — 8 to 14 days
Normal — more than 14 days
This gets logged to the Sheet and shown in the Slack alert so the team knows at a glance which RFPs need immediate attention.
The Slack alert
📋 New RFP Received
Project: IT Infrastructure Modernization
Organization: City of Austin
RFP #: 2025-IT-0042
⏰ Deadline: March 28, 2025
Days Remaining: 11 (High)
💰 Budget: $500,000 - $1,200,000
📝 Requirements:
• Required: 14
• Preferred: 6
• Questions: 8
Evaluation Criteria:
Technical Approach: 40%
Past Experience: 30%
Price: 20%
Team Qualifications: 10%
Sales team sees the evaluation weighting in the alert itself. They know before they open the document that 40% of the score is technical approach.
What lands in Google Sheets
Each row: RFP Number, Project Title, Organization, Deadline, Days Remaining, Urgency, Budget Min, Budget Max, Required Items, Total Requirements, Questions to Answer, Source Email, Received Date, Status
Status defaults to “New” — update it manually as the proposal progresses (In Progress, Submitted, Won, Lost).
You’ll need:
Gmail account (where RFPs arrive)
Google Sheets (free)
n8n instance (self-hosted — uses PDF Vector community node)
PDF Vector account (free tier: 100 credits/month, roughly 25-30 RFPs)
Slack (optional — delete the last node if not needed)
About 15 minutes to configure.
Download
Workflow JSON:
github.com/khanhduyvt0101/workflows
Full workflow collection:
Setup Guide
Step 1: Get your PDF Vector API key
Sign up at https://www.pdfvector.com — free plan works for testing. Go to API Keys and generate a key.
Step 2: Set up your Google Sheet
Create a new spreadsheet with these exact headers in Row 1:
RFP Number | Project Title | Organization | Deadline | Days Remaining | Urgency | Budget Min | Budget Max | Required Items | Total Requirements | Questions to Answer | Source Email | Received Date | Status
Copy the Sheet ID from the URL.
Step 3: Import the workflow
Download the JSON from GitHub and import into n8n via Import from File.
Step 4: Configure the nodes
Gmail Trigger:
Connect your Gmail account (OAuth2)
Watches all incoming email — add a label filter if you want to limit to emails labeled “RFP” or from specific domains
Get a message:
Same Gmail credential
downloadAttachments: trueis already set
PDF Vector - Extract RFP:
Add new credential (Bearer Token type)
Paste your API key
Note: uses
attachment_0as the binary property name — this is correct for Gmail attachments
Analyze RFP:
- No config needed — deadline parsing and urgency calculation happen automatically
Log to RFP Tracker:
Connect Google Sheets
Paste your Sheet ID
Alert Sales Team:
Connect Slack
Paste your sales channel ID
Step 5: Test it
Send yourself a test email with an RFP PDF attached. Wait about 30 seconds and check your Sheet and Slack channel.
Accuracy
Tested on government RFPs, corporate RFQs, and consulting proposal requests.
Project title, organization, RFP number: ~97% on digital PDFs
Submission deadline: ~94% — handles most date formats including “March 15, 2025 at 5:00 PM EST”
Requirements extraction: ~91% — occasionally misses requirements embedded in paragraph text vs. bulleted lists
Evaluation criteria with weights: ~88% — works well when criteria are in a table or list, less reliable when weights are described in prose
Budget range: ~85% — some RFPs deliberately omit budget or describe it vaguely
Scanned PDFs: drops to ~82% overall. Deadline parsing is most affected.
Cost
Each RFP uses about 3-4 PDF Vector credits. Free tier of 100 credits gets you roughly 25-30 documents per month.
Basic plan is $25/month for 3,000 credits if you’re handling volume.
Customizing it
Add a label filter to Gmail:
In the Gmail Trigger node, add a label filter so it only processes emails tagged “RFP” in your inbox. Prevents the workflow from triggering on every incoming email.
Add urgency-based routing:
Insert an IF node after Analyze RFP to split Urgent vs Normal RFPs into separate Slack channels — one for immediate action, one for regular pipeline.
Track win/loss rate:
Add a column to your Sheet for Outcome (Won/Lost/No Bid) and update it after each RFP resolves. After a few months you’ll have data on which types of RFPs you win most often.
Connect to a CRM:
Replace or supplement the Sheets node with an HTTP Request node to create a deal in HubSpot, Salesforce, or Pipedrive automatically. The extracted fields (organization, budget, deadline) map directly to CRM deal fields.
Limitations
Requires self-hosted n8n (PDF Vector is a community node)
Watches all Gmail — add label filtering for production use
Evaluation criteria weights are only as reliable as how clearly they’re written in the RFP
Doesn’t generate the actual proposal — that’s still a human job. This handles intake and analysis only
Multi-attachment emails will only process
attachment_0— if the RFP spans multiple files, you’ll need to modify the binary property handling
Links
PDF Vector n8n integration: n8n Integration - PDF Vector
Full workflow collection: GitHub - khanhduyvt0101/workflows: Awesome PDF Automation Workflows - A curated collection of ready-to-use automation workflows for PDF processing and document extraction · GitHub
n8n docs: https://docs.n8n.io
Questions? Drop a comment if something’s not working or you want to extend it with proposal generation.
