Hey fellow automators,
I’m incredibly proud to announce a project I’ve poured my passion into for the n8n community: n8n-tutorial.com. This isn’t just a collection of articles; it’s a comprehensive learning hub designed to take you from beginner to expert.
To create the best possible learning experience, I’ve also integrated high-quality YouTube video tutorials directly into the written guides. I’ve done the work of finding the best visual explanations so you get clear, step-by-step instructions and hands-on video demonstrations—all in one place.
I’ve organized the entire site into a logical learning path, covering everything from Getting Started and Core Concepts to Advanced AI Features and Deployment & Scaling.
To give you a glimpse of the depth and breadth of what you can learn, here are some of the practical, step-by-step guides you’ll find inside:
1. Connect n8n to Any LLM in 2 Mins with OpenRouter
Stop being locked into one model. This guide shows you how to use OpenRouter to access hundreds of LLMs (like GPT-4o, Claude 3, Llama 3) within your n8n workflows.
2. Build a Free AI Agent: Automate Overdue Invoice Reminders
Move beyond simple workflows. Learn to build a smart AI agent that understands context, checks payment statuses, and sends personalized overdue invoice reminders automatically.
https://n8n-tutorial.com/tutorials/n8n/workflow-design/what-is-n8n-ai-agent
3. Automate Viral AI Videos for FREE: n8n + Veo 3 Integration Guide
Step into the future of content creation. This tutorial walks you through automating the entire process of generating cutting-edge AI videos with Google’s Veo 3 model.
4. Mastering n8n Error Handling: A Single Workflow for Unlimited Coverage
Build with confidence. Implement a robust, centralized error-handling system that monitors all your other workflows and notifies you instantly of any failures. A must-have for any serious user.
5. Mastering Webhooks in n8n: A Comprehensive Guide
Unlock real-time automation. This deep dive explains how to use webhooks to trigger workflows from any external service, handle parameters, and send back dynamic responses.
https://n8n-tutorial.com/tutorials/n8n/workflow-design/how-to-use-webhooks-in-n8n-step-by-step
6. Install n8n Locally for Free with Docker
Take full control of your automation stack. This guide provides a clear path to installing and running n8n on your own machine for ultimate privacy and power.
https://n8n-tutorial.com/tutorials/n8n/deployment-and-scaling/how-to-install-n8n-on-windows
This is just the beginning. I’m committed to continuously adding more tutorials. I built this for the community and would love to hear your feedback and suggestions.
Hope it helps you build something amazing!
