I want to sell automations to clinics and I’d really appreciate some guidance on the right architecture for scaling from a few clinics to dozens.
I’m trying to design an architecture that:
Keeps each clinic’s data isolated and secure
Lets me scale from 1 → 5 → 50 clinics without the whole system becoming spaghetti
Allows adding new automations without breaking existing ones
Is simple enough for an MVP but not a dead-end long-term
I need advice on
Best practices for multi-tenant architecture in n8n
How to structure workflows to avoid duplication and keep things maintainable
Whether to split logic into multiple n8n instances or keep one instance with separation logic
How others handle scaling, security, and per-client logic inside n8n
Any examples, patterns, or recommendations would be hugely helpful.
Thanks!
