I have a problem with goggle sheet and if
Need help with n8n workflow: Google Sheets lookup with filters returns 0 items for non-existent records, but the IF node isn’t routing to the FALSE branch. How do I make it continue to ‘new contact’ flow when no match is found?"
  • n8n version: comunity
  • Database (default: SQLite): yes default
In your case::
  • Enable “Always output data” only on the Google Sheets node, not on the IF node.
  • In the IF node, just test if {{ $json }} “is empty” to decide between “contact exists” and “new contact.”
This way you avoid the issues mentioned above and can still proceed to the “new contact” flow when there’s no match.
Give that a try and let me know how it goes! :blush:
Hi @Ing_Diego_Bustos Welcome!
Just enable “Always Output Data” and configure your IF node to check if {{ $json }} (Is Empty) to correctly route empty results to your new contact flow.
aa
If in the Google Sheets “Search” node I need its output to return the Telegram ID number in order to indicate that it exists, and then in the IF node I want to use that ID as input to determine whether it exists in the sheet, but in the output I get “No fields – item(s) exist, but they’re empty”, I think this is where the problem is, and that’s why it always goes down the new contact branch.
@Ing_Diego_Bustos
When Google Sheets → Search doesn’t find any records and “Always Output Data” is enabled, n8n returns an empty item, not zero items. That’s why the IF node shows “No fields – item(s) exist, but they’re empty” and any test based on the Telegram ID fails, making the flow always fall into “new contact.”
solution
  1. Keep “Always Output Data = ON” in Google Sheets → Search
  2. In the IF node, don’t test fields; just test:
Value 1: {{ $json }}
Operation: Is Empty
  1. TRUE → empty item → New contact
    4.FALSE* → item with data → Contact exists (use the Telegram ID only after the IF)
Hope this work!
@Ing_Diego_Bustos To fix this, keep ‘Always Output Data’ enabled on the Search node, but in the IF node just test if {{ $json }} is empty to decide:
  • NOT empty = contact exists
  • empty = go to ‘new contact’ flow.​
If you need the Telegram ID when it exists, you can still read it from the same item on the TRUE branch; on the FALSE branch you’ll just work with an empty item and create the new contact.
