My Connection tested successfully on both qradar and thehive.
I pulled offenses from qradar and added some conditions to my workflow. Until here, everything was fine, but then i added thehive node and try to create case about offenses, I got this error:
" Problem in node ‘TheHive’
The resource you are requesting could not be found "
and also related with this error → " The resource you are requesting could not be found /case
Error code 404
Full message
{ "type": "NotFoundError", "message": "/case" }
Note: My thehive and n8n are located in different workstations.
**n8n version:1.63.4 (Self Hosted)
**Database: SQLite
n8n EXECUTIONS_PROCESS : default: own, main
Running n8n via Docker
If you have an idea about the solution, please share with me.
Would be good to know how you’ve configured your TheHive node. Can you please share your workflow?
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
