When I use queue and worker to run n8n, some complex workflow sent many sub-workflow. But it never done. When I see executions:
It just done the last sub-workflow
The first workflows before seems run, but have been eaten by others which go after.
That first workflow have run, but disappeard fast. And then it never report to be done
Its tasks failed too. Everything happened like nothing work.
This do not happened with single workflow
Do you know this issue?
This is log from worker
Start job: 8 (Workflow ID: 56 | Execution: 2044)
Start job: 9 (Workflow ID: 56 | Execution: 2045)
Start job: 10 (Workflow ID: 56 | Execution: 2046)
Start job: 11 (Workflow ID: 56 | Execution: 2047)
Start job: 12 (Workflow ID: 56 | Execution: 2048)
Start job: 13 (Workflow ID: 56 | Execution: 2049)
Start job: 14 (Workflow ID: 56 | Execution: 2050)
jan
November 29, 2021, 10:34am
2
Sorry do not fully understand what the problem is you are seeing but the following is important to know:
If you do not set in the workflow settings of a sub-workflow that it should be saved on success, then its data will get deleted directly after the execution is done
A sub-workflow does not start a new workflow execution on a new worker. It simply runs in the same execution and on the same worker the main workflow got started on.
Sorry when I used “sub-workflow”
In fact, it is 2 different workflows, I just call the second one by request → webhook in the first one
That means, I just see the second success, and the first workflow just run fast, and then disappeared forever.
I found there is a workflow sent to worker and it seems to run
But then it is disappeared, without any error log or failed execution
When single workflows are alright, the complex one have this problem
I think this is main problem. Do you know how to solve this?
Sorry, I found there is an issue with my plugin
Today, newest upgrade broke all data of webhook links. This caused problem.
I will check this. Thank you anyway for answer me.
