I try to send command from slack
And slack bot return this notification:
/command failed with the error “operation_timeout”
But at the end, command is still successful
How could I solve this?
I read a instructions about “sending a post message of confirmation to slack” here:
But don’t know exactly how to do with n8n?
As far as I know does Slack expect an answer within 3 seconds. If it takes longer then it will time out. So you either have to make sure that the workflow returns fast enough, or if it is not possible set the Webhook-Node to Response Mode: "On Received"
that it returns directly and then send the response manually either like in this example:
or by sending the Response to the URL which you did receive via the Webhook-Node.
Sadly will there currently always be the message “Workflow got started” be displayed.
Yeah, “Workflow got started” is always
Some workflow for chat through email wants just “nothing” among communications of slack
Zapier has an option like “silent mode”. I don’t know how they did. Hook json to this node which has this option, will return nothing. I could choose this if I 'm sure that everything done well…
