I’ll help 5 n8n freelancers build a free AI lead generation system for their own services
I noticed many talented n8n / AI automation builders here are great technically… but spend too much time waiting for clients to find them.
So I’m testing something:
I will help a few freelancers set up a simple AI-powered outbound lead generation workflow that finds potential clients automatically.
The system can:
:white_check_mark: Find companies that may need automation services
:white_check_mark: Collect business emails and company information
:white_check_mark: Analyze if they are a good fit using AI
:white_check_mark: Generate personalized outreach messages
:white_check_mark: Organize leads inside Airtable / Google Sheets / CRM
:white_check_mark: Create a daily pipeline of potential opportunities
Example:
Instead of sending:
“Hi, I build n8n workflows. Do you need help?”
You get:
“Hi John, I noticed your company is using multiple manual processes for onboarding. I built a workflow that could reduce repetitive admin work by connecting your CRM, forms, and AI assistants.”
Much higher chance of getting a reply.
The goal is not another demo workflow.
The goal is to create a practical client acquisition machine that you can use for your own freelance business or show as a portfolio example.
I’m opening a few spots for n8n builders who want to test this system.
DM me if you want access.
I’ll share the workflow structure and help you adapt it to your niche.
This really resonates. Most of the strong n8n/AI builders I know spend way more time waiting for work to show up than actually building workflows.
A practical outbound system that can be reused and adapted as a portfolio asset is honestly more valuable than yet another cool demo. Curious to see how people niche it down for specific services.
I’ve been experimenting with a small project called agentscoutjobs that’s also focused on helping automation freelancers get in front of more of the right businesses, so this approach definitely caught my attention.
Thanks, I really appreciate your interest! Let’s connect on WhatsApp—I’ll be happy to tell you more, show you how the system works, and answer any questions you have.
WhatsApp: +375 29 376 1570
