I need help, error send message in whatsapp
i check, delete and reload the number, but i cant send message from my board
to whatsapp number…
Hello
I’ve seen this come up quite a few times, so worth checking some other posts, but it seems that you need to add the phone number into the allow list on the app side in meta, When you’re using in development mode, Meta only allows sending messages to phone numbers that you have explicitly added and verified in your developer console.
Best regards,
Samuel
