I need help finishing my automation
This is my first automation in n8n but I have been using make.com for about a year. I am trying to take data from a folder listing page on the NM legislative website, parse the links, then split the pdf links from the html links. Once in html I need it to pull the data of the page, get rid of all the code and markup, then run it through open ai to get some info from it including a synopsis, then run the synopsis through google gemini to have it match to a list of my wifes client keywords. I have all of this working to here, maybe not correctly, but where I am getting stuck is trying to get the data into a google sheet. I am being met with undefined and node path errors like crazy. Thank you in advance for any help.
Node path errors and undefined.
“errorMessage”: “Info for expression missing from previous node”,
“errorDetails”: {},
“n8nDetails”: {
“itemIndex”: 0,
“runIndex”: 1,
“parameter”: “columns.value”,
“causeDetailed”: “Missing pairedItem data (node ‘Code Cleanup 1’ probably didn’t supply it)”,
“time”: “1/14/2025, 5:31:07 PM”,
“n8nVersion”: “1.73.1 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“ExpressionError: Can’t get data for expression”,
" at createExpressionError (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:484:20)“,
" at createMissingPairedItemError (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:503:20)”,
" at getPairedItem (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:570:27)“,
" at pairedItemMethod (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:816:40)”,
" at Object.get (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/WorkflowDataProxy.js:819:40)“,
" at Proxy.eval (eval at getFunction (/usr/local/lib/node_modules/n8n/node_modules/@n8n/tournament/dist/FunctionEvaluator.js:14:22), :6:54)”,
" at FunctionEvaluator.evaluate (/usr/local/lib/node_modules/n8n/node_modules/@n8n/tournament/dist/FunctionEvaluator.js:20:19)“,
" at Tournament.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/tournament/dist/index.js:43:31)”,
" at evaluateExpression (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/ExpressionEvaluatorProxy.js:123:16)“,
" at Expression.renderExpression (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Expression.js:238:70)”
  • n8n version: Version 1.73.1
  • Operating system: CasaOS on Ubuntu
It seems code cleanup 1 don’t receive the data from previous node
