Here my workflow to get only pdf from Gmail and upload to Google Drive and Append in g sheet .
My problem is ones i upload a pdf i want to filtered out the existing pdf in Google Drive , I want to upload only new pdf.
I am can’t able to do this , please Help me
There are different ways to achieve this functionality.
How I would go about this:
- Create a Label in Gmail e.g.: “Uploaded”
- Filter your received Gmail messages, so only proceed with the items that are not having this label
- When successfully uploaded, add the label via Gmail node to the email item
Another option:
- Add a column to your sheet that is populated with the Gmail message Id
- Filter your gmail items by this Id and only proceed with the items that are not in your sheet
- When appending the row in sheet, add the message Id
What if you append the row before adding the PDF to your drive? Then your flow will know what’s already been added and only add the new PDF.
Hey @For_n8n_learning !
Between your Code and the Drive nodes, you can put an “Remove Duplicates” node…
It has a very extensive flexibility, for remembering node or workflowexecution data.
Check here docs :
Cheers!
This problem has bin Solved
