I need help with my ai think mode
The thinking mode is not working and causing issues as you can see in the image, any solutions please?
Hi @elalamiimed, is the thinking tool attached in the AI agent?
No issue
Posting multiple threads on the same forum will not get you faster answer
From your error message, according to how you set your AI agent, you are supposed to provide it with a reasoning_content, thus an input it needs to use to think, you have failed to provide that content and that is why. I advise you to trace back to your main AI agent node (the orchestrator) and ensure that you provide it with the reasoning content: some prompt or message it needs to work with.
Instead of models like:
  • kimi-k2.6
  • reasoning models
  • o1/o3-style models
Use a standard chat model such as:
  • gpt-4.1-mini
  • gpt-4.1
  • gpt-4o-mini
