I am trying to install n8n but I don’t know what node.js version does this use i am getting an error depreciate when I run npx n8n
do you have any idea what the issue is?
- n8n version:
- Database (default: SQLite):
- Operating system:
8n version: 1.762
Database: mariadb
n8n EXECUTIONS_PROCESS setting (default: own, main): this I don’t know
- Operating system: Windows 10
I don’t use docker
Welcome to the community @ecortes91 !
Tip for sharing information
Pasting your n8n workflow
Ensure to copy your n8n workflow and paste it in the code block, that is in between the pairs of triple backticks, which also could be achieved by clicking </>
(preformatted text) in the editor and pasting in your workflow.
<your workflow>
The error message tells you what version of Node.js is supported.
You need to upgrade the Node.js on your PC as you have 18.8 while 18.17 to 22 is expected.
