I pointed a read-only monitor at my own n8n and found 28 failures I'd never looked at
I self-host n8n for client work, and I’ve spent the last couple of weeks reading the threads here about catching workflows that quietly stop doing their job. Last night I finally pointed something at my own instance instead of theorising about other people’s.
It found 28 consecutive failures in one workflow - a social inbox automation - across about 24 hours. Same failing node every time. I had no idea.
The part worth sharing isn’t the count. It’s the two things either side of it.
They were never hidden. All 28 were sitting in my own execution list, correctly marked as errors, for three days. n8n did exactly what it should. I just never opened that page, because nothing told me to. The execution list is a place you have to remember to go and worry, and I didn’t.
The root cause wasn’t in n8n at all. We had migrated the app those workflows talk to from EC2 to Vercel. The migration checklist has a line - “update n8n workflows that call back into the app domain” - that never got ticked. So the node was calling a server that had been switched off days earlier. App side: everything green. n8n side: everything red. Nobody was looking at both.
That’s the failure mode I now actually worry about. Not a bug inside a workflow, but a change made somewhere else that a workflow was quietly depending on. Neither system is wrong. The seam between them is where it breaks, and nobody owns the seam.
Two questions for people running more instances than me:
  • When something of yours broke like this, what eventually told you - a monitor you had set up, or a person downstream asking where their data was?
  • Does anyone actually check their execution list on a schedule, or is it “I look when someone complains”?
Disclosure so it isn’t a surprise: reading these threads is what got me building a small monitoring thing, and that’s what I pointed at myself. I’m not linking it - I’m more interested in the answers than the clicks. Happy to share if anyone asks.
Your line about the execution list being somewhere you have to remember to go and worry is the part I keep re-reading. I had the same shape on my own product and worse — 27 workflow branches skipped for weeks, except mine were recorded as COMPLETED rather than as errors, so opening the page would not have saved me the way it would have saved you. I build a hosted agent tool so I am biased, but I also run my own box and I still did not notice.
After the 28, which side did you actually fix — the migration checklist, or the monitor?
This is the most underrated problem in production n8n — ‘silent failures’. The workflow executes successfully (no error thrown) but nothing actually happened.\n\nThe social inbox automation issue you’re describing is usually one of these:\n\n- API rate limit – The external service started returning 429s, the node caught them silently, and returned empty results instead of an error\n- Empty input – An upstream node returned 0 items, so the rest of the workflow technically ‘succeeded’ with nothing to do\n- Credential token expiry – OAuth token silently expired; some nodes return empty instead of erroring on auth failures\n\nGood pattern to add to all production workflows: a Code node after any node that should return items, with: if ($input.all().length === 0) throw new Error('Expected items, got 0 — check upstream source'); This turns silent 0-item failures into real errors that n8n will catch and alert on.\n\nWhat was the specific failing node in your case? Curious whether it was a rate-limit or a credential issue.
Honestly neither, yet. The monitor found it; the fix is still open. All 28 traced back to one sub-node calling into an app that’s mid-migration between hosts, so the real fix lives in that app’s deploy config, not in the n8n workflow itself. What the monitor did was turn an ambient “seems fine” into a specific, dated thing I now have to go finish. Matches your point exactly the monitor and the fix are two different jobs, and jumping straight to green would have hidden that the migration was ever incomplete.
Neither of those three, actually turned out to be a sub-node calling an internal endpoint that was mid-migration to a new host, so the calls were hitting a dead target. n8n reported it correctly as a node error; the failure was that I never looked at the executions list for a workflow that looked fine by every other signal. Good pattern above though adding the 0-item guard to the ones that can silently return empty too.
That is the part people skip. The monitor turned it into a dated job, and a dated job can actually be finished. I did the opposite once. I fixed the exact deploy miss, called it done, and a week later shipped the same kind of bug again, because I had fixed the instance and not the class. Your way keeps the migration visibly unfinished until it really is.
“Fixed the instance and not the class” is the better phrasing — I’m stealing it.
The part I didn’t expect was how much of the value was just having a date attached to the thing. Before, “the social inbox one is flaky” was a feeling I’d been carrying around for weeks. After, it was 28 failures starting Tuesday, same node every time. The second one you can actually close. The first one you just feel vaguely bad about.
Since you build a hosted agent tool and also run your own box: which side finds your failures first these days something watching from outside, or someone telling you? I’ve been assuming outside in is the only honest answer, but you’d know better than me whether that still holds when the thing being watched is an agent rather than a plain workflow.
Neither, honestly, and nobody tells me because I have no users yet. Almost every failure I found, I found by accident while doing something else. I deleted a scheduled task and it was still in the running schedule, and I only noticed a 403 was invisible because I took a screenshot to show someone. For agents I think outside-in stops being enough. My worst agent run finished COMPLETED in a normal 28 seconds with every tool call recorded, and the failure was one false sentence in the reply, so anything watching the shape would have seen a good run. Are any of your client builds agents yet, or still plain workflows?
I would fix both, but i think the monitor is the durable control.The checklist fixes this specific migration mistake. The monitor is what tells you when the next change somewhere else quietly breaks the workflow again.Your case is even more interesting because ‘COMPLETED’ would have hidden the problem from someone who actually checked the execution list. That’s the gap I keep coming back to: execution state is useful, but the downstream business state is what ultimately has to tell you whether the job was really done.
A person downstream never sustains it past week two. Self-hosted n8n already exposes Prometheus: set N8N_METRICS=true plus N8N_METRICS_INCLUDE_WORKFLOW_STATISTICS=true (both default off), then alert on the failed-execution counter instead of on someone remembering to check.
The other half is the Error Workflow field in each workflow’s Settings — it fires on every failed execution and hands you the workflow name and error in the payload.
For the EC2-to-Vercel class of break, though, what catches it is a check from the n8n box that the host your nodes call still resolves. That is the dependency neither side considers theirs.
@Aghassi plain workflows so far, no agents in the client builds yet. Which means I have been designing for the easier case without realising it. Your run that finished COMPLETED in a normal 28 seconds, every tool call recorded, and the failure was one false sentence in the reply I have no answer for that at all. Anything watching the shape sees a good run. Mine included.
@Mcpherson_AI execution state is useful, but the downstream business state is what ultimately has to tell you whether the job was really done" is the sentence I keep failing to argue with. Someone made the same point to me privately this week: they reprocessed eight documents, every operation reported success, and the fixed documents quietly travelled back and overwrote an accountant’s work on the other side. Nothing failed.
@Visaroy that is the most useful correction in the thread, thank you. N8N_METRICS plus N8N_METRICS_INCLUDE_WORKFLOW_STATISTICS and the Error Workflow field do cover the failed-execution case natively, and I should stop treating that half as though it were hard. Your last line is the one I would underline: a check from the n8n box that the host your nodes call still resolves. That is the dependency neither side considers theirs, and it is exactly the class my EC2-to-Vercel break belonged to.
So the honest summary of my own week: the piece I built something outside noticing a workflow that should have run and didn’t is real but narrower than I thought. The error half is largely already in the box. And the part that keeps getting described as the actual problem, the seam between two systems that both report success, is the part nobody here has a clean answer for, me included.
If anyone has genuinely solved the seam rather than worked around it, I would like to know what that looked like in practice.
No, and here’s where we stopped.
We watch from outside and store metadata only, so the seam is invisible to us by design. The concrete blocker: n8n’s public API doesn’t put item counts in the executions list. To see counts you fetch each execution with includeData=true, and the response then hands you the whole payload. We do that only for failed runs, and keep the node name plus the error message. Doing it for every green run, which is what counting would need, means holding your clients’ data all day.
The nearest thing to an answer I’ve seen is @Jarvis1’s reconciler in Silent-success reconciler: a sub-workflow that refuses to mark a run green unless the provider confirms it (full JSON) read the record back from the provider by business key and refuse to promote unknown to success. Costs one extra read per action and needs provider-specific code for each response shape, so it’s wiring per workflow.
Since it’s in the account name, we build the outside monitor, which makes the seam the case we don’t cover.
Not sure that’s solvable for an agent’s reply.
No, I have not solved it either. The one place I did was narrower than the seam: my deploy script stopped checking status and started checking effect, a container younger than 15 minutes, and that only works because I own both sides. For the agent case I am worse off than you think. My tool layer still records a 403 as ok: true, so I am promoting unknown to success today, which is exactly the rule @Jarvis1 wrote down in his reconciler post. The other half I cannot check at all: the run says the email sent, and that only proves a provider accepted it. I asked three people building in this space whether anyone has a standing check that the thing arrived and was read, and none of them did.
The email half is two different questions, and only one of them has an answer.
Whether it arrived you can get, just never from the run. SMTP gives you a 250 from the next relay and nothing else, so the run is telling you the truth about the wrong thing. The bounce turns up minutes or hours later at a completely different door, because Postmark, SES and the rest post delivery and bounce events to a webhook you register once. That’s the standing check you asked about, and it sits outside the execution by construction.
Whether it got read is the one I’d give up on. Apple’s Mail Privacy Protection pre-fetches the tracking pixel, so opens get reported for mail nobody opened.
We don’t consume those events either. Our own alert mail goes out over plain SMTP, one send call and a log line, so if an agency’s alert address starts bouncing we’d never hear about it. Since it’s in the account name, that one stings.
That is the answer, thank you. So the run can only ever tell me that a relay accepted it, and the truth turns up later at a different door. Mine is the same shape as yours: my own mail goes out over SMTP with one send call and a log line, so verification and reset mail that bounces is invisible to me too. My provider posts those events and I do not consume them, which makes it available and unbuilt rather than hard. Giving up on whether it was read is the part I would have argued with a week ago, and the Apple pre-fetch settles it.
The scenario @Loontha_brevismar described—where n8n reports 100% success while silently overwriting an accountant’s downstream data due to an unhandled upstream drift—is honestly the scariest failure mode in production B2B automations.
In our experience monitoring high-stakes client pipelines (especially Stripe, CRM webhooks, and ERP syncs), standard error nodes in n8n fall short because:
  1. The HTTP layer succeeded: The webhook responded 200 OK, so native alerts never fire.
  2. Schema mutated upstream: A key silently dropped or shifted type (e.g. amount sent as null or wrapped in a nested object), leading downstream nodes to write falsy/null values over valid database rows.
To prevent this without bloating every single workflow with defensive Code nodes, two architectural patterns actually work:
  • Contract Enforcement at the Edge: As @DashboardWatch mentioned, you intercept before n8n. If an incoming payload breaks an immutable contract (financial values, customer IDs), fail loud immediately into a quarantine dead-letter queue.
  • Deterministic Field Repair: If it’s a structural renaming drift (e.g., data.transcript moved or stringified JSON), align it deterministically before downstream consumption.
We ended up building an autonomous healing proxy (Blacksmith) precisely for this nightmare after seeing too many silent webhook corruptions in client setups.
Curious how you guys currently handle schema contracts on mission-critical workflows? Are you placing JSON-schema validator nodes before every sensitive DB write, or relying strictly on downstream database constraints?
@Loordhu_Jeyakumar
That second example is the part that really gets me.
Every component can be green, every call can succeed, and the business outcome can still be wrong.
That’s why I keep separating execution evidence from outcome evidence. Once workflows cross multiple systems, the seam between them becomes the real risk.
Separating execution evidence from outcome evidence is the distinction I keep coming back to as well, and I think there is a middle you can reach from the near side.
@mouadkommir put it better than I can over in the 20+ workflows thread: he went back through 352 failed jobs across 89 accounts and found one account with 167 attempts and 0 successes. Every one of those was a correctly reported error. One of them is execution evidence. All 167, grouped by account, is outcome evidence a customer for whom the product has never once worked and you can compute it without touching the far system at all.
The catch is the denominator. A ratio only means something if you know what should have been attempted, and for anything webhook-driven there is no expected count to compare against. So it narrows the gap rather than closing it, which is roughly where I have landed on the seam in general.
“Nothing told me to look” is the part that applies to almost everyone. The executions page is a pull. Most people need a push.
If anyone reading wants the push without a tool: a scheduled workflow that reads GET /api/v1/executions every 15 minutes, keeps the last check time in static data, and posts any new error or crashed runs to Slack. That turns your 28-over-3-days into one message within 15 minutes of the first. We shared one here: Free workflow: get alerted on failed runs and on workflows that stop running (6 nodes)
It won’t catch Aghassi’s case, where branches were skipped but the run was recorded as completed. Status-based checks can’t see that. You need either a guard inside the workflow (IF no items into Stop and Error) or a check on how many items a specific node produced.
