I want to learn N8N where can i start
Heyy developerss. im new to this platform but i want to level up my play. so i would respect it if anyone could suggest me where to learn.
Welcome to n8n! Here’s the fastest path to actually knowing what you’re doing:
Start here (official, free):
  • n8n’s own docs have a “quickstart” section that walks you through your first workflow in about 15 minutes. Start there to understand the basic trigger-node-output mental model.
  • The n8n YouTube channel has beginner walkthroughs for common use cases (web scraping, CRMs, Slack notifications).
Once you get the basics:
  • Pick ONE real problem you want to automate. Build it. Break it. Fix it. You’ll learn 10x faster with a real goal vs. following tutorials for the sake of tutorials.
  • Good beginner projects: auto-save email attachments to Google Drive, get a Slack/Discord message when something happens (new form submission, new row in a sheet, etc.)
The things that trip everyone up early:
  • Understanding data flow – n8n passes JSON between nodes. Spend 20 minutes just clicking through the “Input” and “Output” panels on nodes until that clicks.
  • Expressions – {{ $json.fieldName }} is how you reference data from previous nodes. This is the thing that makes everything work.
  • The difference between “Test” mode and actual live executions.
Community tip: When you get stuck (you will), search this forum first. Most common issues already have answers. If you post a question, include your n8n version, a screenshot of the workflow, and the exact error message – that gets you much faster help.
What kind of automations are you hoping to build? Happy to point you at more specific resources.
The best way to get started is docs.n8n.io
You can also start with the n8n text course: Index | n8n Docs
Want a quick overview? You may refer to my video if you wish:
