Describe the problem/error/question:
When running n8n in kubernetes, my svg for my custom node is not loading. I am getting:
Request Method
GET
Status Code
404 Not Found
I have checked that the files exist it just feels like the way that n8n is try to resolve tha path is wrong:
other then this the custom nodes are loading and working
Sample Trigger Description:
description: INodeTypeDescription = {
displayName: "Custom Trigger",
icon: "file:custom.svg",
group: ["trigger"],
version: 1,
description: "Triggers workflows based on custom trigger",
subtitle: "Overlapping Detections",
defaults: {
name: "Custom Trigger",
inputs: [],
outputs: [NodeConnectionTypes.Main],
credentials: [
required: true,
gulpfile:
const path = require('path');
const { task, src, dest } = require('gulp');
task('build:icons', copyIcons);
function copyIcons() {
const nodeSource = path.resolve('nodes', '**', '*.{png,svg}');
const nodeDestination = path.resolve('dist', 'nodes');
src(nodeSource).pipe(dest(nodeDestination));
const credSource = path.resolve('credentials', '**', '*.{png,svg}');
const credDestination = path.resolve('dist', 'credentials');
return src(credSource).pipe(dest(credDestination));
docker file to build node:
# https://github.com/n8n-io/n8n/blob/master/docker/images
ARG NODE_VERSION=22
FROM node:${NODE_VERSION}-alpine AS build
WORKDIR /build
# Install Node.js dependencies
COPY package*.json ./
RUN npm ci
COPY build.js gulpfile.js tsconfig.json ./
COPY credentials/ ./credentials/
COPY nodes/ ./nodes/
COPY python_blocks/ ./python_blocks/
ARG APP_VERSION
ENV APP_VERSION=${APP_VERSION}
RUN echo Setting npm version: ${APP_VERSION} && \
npm version --force --no-git-tag-version ${APP_VERSION}
RUN npm run build
RUN npm pack
FROM node:${NODE_VERSION}-alpine AS runtime
WORKDIR /app
# Copy assets from build stage
COPY --from=build /build/*.tgz ./
I am using:
- name: N8N_CUSTOM_EXTENSIONS
value: /home/node/.n8n/node_modules/custom-n8n-nodes
Just the 404 error
information on your n8n setup
instance information
Debug info
core
- n8nVersion: 1.110.1
- platform: docker (self-hosted)
- nodeJsVersion: 22.19.0
- database: postgres
- executionMode: scaling (single-main)
- concurrency: -1
- license: community
- consumerId: unknown
storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: memory
pruning
- enabled: true
- maxAge: 336 hours
- maxCount: 10000 executions
client
- userAgent: mozilla/5.0 (macintosh; intel mac os x 10_15_7) applewebkit/537.36 (khtml, like gecko) chrome/139.0.0.0 safari/537.36
- isTouchDevice: false
Generated at: 2025-09-15T19:09:20.920Z
