If a person has to approve every run, is it still automation?
One argument against approval steps is that they show you do not trust your own workflow. Build it properly, the thinking goes, and let it run.
I get it, but for anything a client or a customer will see, I disagree.
Look at what the person actually does in a good approval step. The workflow has already found the problem, pulled the data, written the change and checked it against the source. The person reads two lines in Slack and presses a button. That is ten seconds of work replacing an hour. To me that is still automation, just with a seatbelt on.
Where the critics have a point: an approval that never gets rejected is pointless. If people press Approve without reading, you have added a delay and no safety.
So here is how I decide if an approval step should stay:
  1. Count how many approvals in the last month were declined or edited.
  2. If it is zero after plenty of runs, the step is either catching nothing or nobody is reading it. Work out which.
  3. If it catches real mistakes, keep it, and make the Slack message short enough that people actually read it.
  4. Make no answer count as no. If nobody responds, nothing changes.
My full version is my Shopify audit template. Claude rewrites weak product descriptions, code throws out any rewrite with facts that are not in the product data, and Shopify only changes after someone presses Approve. If nobody answers, nothing happens. You can find it in the n8n template library under my name.
So which side are you on? Do you keep approval steps forever on client-facing work, or remove them once the workflow has proven itself? And how do you decide when it has?
Keep the approval for anything the client will see and measure it instead of guessing. I track how often an approval gets declined or edited after a few weeks - if it is genuinely catching mistakes, keep it; if it is just a rubber stamp, cut the click and keep the notification. An approval that never gets a real decision is a delay, not a safety net. Automation with a seatbelt is still automation, as long as the seatbelt actually gets checked.
I keep it on everything a customer reads. Nothing AI-written goes out under my name without me sending it myself. The approval only stays cheap if the draft is close, so my rules for tone and for what the model may never promise live in a file it reads on every run. That way I mostly check facts like dates, prices and commitments, which takes seconds.
On your counting idea: I’d count what kind of edit it was. Tone changes don’t tell you much. A wrong date or a promise that wasn’t made is the reason the step exists, and as long as those still show up now and then, the step stays.
A second AI is not a seatbelt
Our case (Telegram assistant):
  • :bust_in_silhouette: A customer asks about the price.
  • :robot: Mistral Small answers: the price “includes” two months of support.
  • :cross_mark: Wrong. It was a time-limited bonus.
  • :robot: A second model (Mistral Medium) checks the answer. It says “fine”.
  • :white_check_mark: We found the mistake ourselves.
  • :police_car_light: Lesson: a second model helps, but it does not replace fixed rules.
What we changed
  1. A Code node checks price answers before they are sent.
An idea for approvals
@solonaut.ai is right: the reviewer should check prices, dates and promises. But you don’t need a click on every run. You only need it on the risky ones.
  1. After the AI Agent, add a Code node with fixed rules: does the reply mention a price, a date, “free” or “included”?
  2. Add an IF node. Rule matches → approval. No match → send directly.
  3. Approval: Telegram node → Send and Wait for Response → Response Type Approval. Turn on Approve Within Chat, so the team only taps a button.
  4. Set Limit Wait Time. If nobody taps in time, the workflow continues. Make sure this path sends a safe message (“A colleague will reply soon”), not the AI draft. This is @Kingsley_Ken’s “no response = no change” rule, built into the workflow.
  5. Test it once with a very short wait time.
Do you send all replies to a human, or only some? Which rule catches the most mistakes for you?
Thanks for the mention. For me it’s still all of them, but my volume is small and very little of it is customer chat, so one click per item costs me almost nothing. For a Telegram assistant with real traffic your split makes a lot of sense.
One thing I’d add to the IF node: log which rule fired and whether the human changed the reply. After a few weeks you can see which rules never catch anything and which ones do the real work.
I would keep approval on anything customer-facing or hard to undo, and decide the rest by risk rather than by how long the workflow has been running. The rejection count you describe is a good measure, and one addition is to track why a step was rejected, because a pattern in the reasons often points to a fix in the workflow itself.
When a workflow has proven itself, a middle option is to approve automatically for low-risk cases (for example, small changes that pass every validation check) and send only the unusual ones to a person, with a small random sample still reviewed each week. That keeps the safety benefit while removing most of the routine clicking. Your point that no answer should count as no is, in my view, the most important design rule here.
Thank you, @solonaut.ai. Logging which rule fired is now on our list. Every held answer in our Telegram assistant already shows what was not in the price list. Next we’ll also save whether we changed the draft.
Thank you, @williamsj04. The reason field is a good addition. And your random sample: we already do something similar. A second model reviews about 10 % of the normal answers.
So right now:
:white_check_mark: normal answers go out directly
:pause_button: prices, dates, discounts or “included” that are not in our price list wait for the team
:magnifying_glass_tilted_left: about 10 % of the rest get a random second look
@williamsj04 — the random 10% second-model review is a smart way to keep a safety net without slowing the routine cases. One thing worth checking: are you logging why the second model flagged something, not just that it did? A pattern across those flags often exposes gaps in the price list or the rules. You could also review the sampled answers in batches weekly rather than per-message, so it stays lightweight for the team. Good call on capturing whether the draft was changed — that plus the reason field should give you a clearer picture of where to fix the workflow itself.
Thanks – good point. A flag without a reason doesn’t teach us much.
We’ll make the second model return one short reason with every flag (price, date, promise, tone or other) and add a column for whether the team changed the draft.
A weekly batch review fits us better too: one short look on Monday instead of reacting to every single flag.
If the same reason keeps showing up, it’s usually a missing line in our price list, not a model problem. We’ll share what we find.
