Output returns no Data, but next flow HTTP Request node is not working, can anyone helps if data is empty it should run the next node, I tried all but not working
That is what the option “Always Output Data” is for. It can be found underneath “Settings”:
But output data is empty how to pass it accordingly if data found then do this else do this
