IF node condition not matching webhook data from GoHighLevel
Hi,
I’m building a workflow where I receive data from GoHighLevel via a Webhook → IF node → Twilio WhatsApp.
Everything works fine until the IF node. The webhook captures the data correctly, and I can see: “pipeline_stage”: “Onboarding bokad” In the IF node I set:
{{ $json[“body”][“pipeline_stage”] }}
is equal to
Onboarding
But it never matches, so the Twilio node doesn’t get triggered.
Should I use contains instead of is equal to?
Could this be a string formatting issue (extra spaces, capitalization, etc.)?
Is there a better way to ensure the IF node matches the webhook value reliably?
Thanks in advance
Hey @sedii hope all is well. Welcome to the community.
Could you please pin data in the trigger and share your workflow?
