Oh I see, thank you. That worked. But I’m afraid that if I use ‘contains 0’ statement, errors may occur when input is 10, for instance. Is there a way to turn this output into a number in n8n?
Hey @alexpti4ka,
Javascript has a handy Number()
function that will convert a string to a number, Take a look at the workflow below that shows how you can use it in an If Node.
