Note: I have seen other threads about some similar topic, they basically suggest to create a new workflow, create the “Email trigger (IMAP)” node and copy the rest of previous workflow to new one. It works for some time, and then I get same error again…
I am running a workflow that works (for a while). It is deployed via docker-compose.
The workflow as a “Email trigger (IMAP)” node and I suspect it is the reason why part of it won’t work after some time.
Work flow consists of :
part 1 : wait if there is a new email, if so, save some info in a DB
part 2 : wait if there is a webhook call, if so, call the DB and return in the webhook.
Part 2 works well.
Part 1 works for some time, after a while it doesn’t anymore (in the sense that if I send emails to the email address, at first it triggers the Part 1 of the workflow, after some time it has no impact at all on the workflow, no error on the frontend n8n)
In the “docker logs <container_id>” logs I see
Removed triggers and pollers for workflow "<id_of_workflow>"
Failed to renew license: renewal failed because current cert is not initialized
note that in my docker-compose i have set up a value for the environement variable N8N_ENCRYPTION_KEY for the n8n service… so unsure about that second error in the logs.
Part 2 is not connected to Part 1. Part 2 works great.
Part 1 is not triggered at all, no error, no output.
- n8n version: 1.47.1
- Database (default: SQLite): Postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): unsure where to look for this info ?
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker-compose
- Operating system: Ubuntu on Hetzner VPS
Any permanent fix help is welcome, even a “trick” to make it work by having something else to trigger the IMAP node on a frequent basis to do the trick…
Was thinking about maybe using the Gmail node but it needs an API account and I feel it is a paid thing and would like to reduce more dependencies…
