Implementing Tenant Schema Isolation with Django Application
Has anyone implemented a similar multi-tenant architecture with n8n? What’s the recommended approach - custom nodes, middleware, or separate n8n instances per tenant? Are there enterprise features or community nodes that might help with this use case?
The TOS requires you to purchase an enterprise or white label license to allow the resale / reuse of workflows by clients, if thats what you mean. Then I believe you can easily fetch per client creds via external secrets:
