Increment a number using Function
Hi
I am hoping to find some help in writing some code to take the result from one number (a number) and then to increment that number by 1.
Hey @Surge.Media,
Quickest way to do it would be to just add ++ after the variable, You could do this in an expression as well so something like {{$json["name"]++}}
Hey @Jon as always thanks for the quick answer.
How exactly would i write this in the function node ?
Try this quick example.
Thanks @Jon !! Solved my issue and expanded my understanding!
