I completed the Level 2 test content on May 13th at approximately 11:00 AM. However, after more than two hours, I have yet to receive my results. I would like to inquire about the status of my test.
@jamiemadden_n8n can you help with this?
Hi @ttn.eee, welcome!
You can verify your level 2 score manually as well, just by entering your unique_id you must have received when you signed up for the level 2 course. Visit here:
Thank you for your reply. I have checked this page, but there is no information available.
I have retaken the exam 3 times already, but I haven’t received the results either here or via email.
Hey @ttn.eee !
Welcome to the n8n community!
You mustve not signed up for the level 2 course. As because i checked this id on level 1 it shows that it’s complete but shows the “Course incomplete” result in level 2.
Most probably the reason is that you havent signed up for level 2 course as you would get a different unique id once you do. and then you can check again with that id.
I’m hoping this is the issue and i hope this helps you.
Let me know if you encounter anything else.
So that i can assist you further.
Hi @Deepankar ,
Thank you for looking into this. I can confirm that I did not successfully register for Level 2. Thank you very much for your assistance.
Thank you @ttn.eee
I’m glad it helped you!
Keep Automating
