Hello n8n community,
Could you help me this error:
connect ETIMEDOUT 2606:4700:20::681a:dbb:443
Error fetching feature flags Error [PostHogFetchNetworkError]: Network error while fetching PostHog
at new PostHogFetchNetworkError (C:\Users\PC\AppData\Roaming\npm\node_modules\n8n\node_modules\posthog-core\src\index.ts:41:5)
at PostHog. (C:\Users\PC\AppData\Roaming\npm\node_modules\n8n\node_modules\posthog-core\src\index.ts:546:17)
at step (C:\Users\PC\AppData\Roaming\npm\node_modules\n8n\node_modules\node_modules\tslib\tslib.es6.js:102:23)
at Object.throw (C:\Users\PC\AppData\Roaming\npm\node_modules\n8n\node_modules\node_modules\tslib\tslib.es6.js:83:53)
at rejected (C:\Users\PC\AppData\Roaming\npm\node_modules\n8n\node_modules\node_modules\tslib\tslib.es6.js:74:65) {
error: DOMException [TimeoutError]: The operation was aborted due to timeout
at node:internal/deps/undici/undici:13502:13,
[cause]: DOMException [TimeoutError]: The operation was aborted due to timeout at node:internal/deps/undici/undici:13502:13
Hi, can you please detail your full setup. What is running where ? A small diagram would be even better.
reg,
J.
