Installed locally trying to run linkedin automation
Problem in node ‘LinkedIn‘
This operation expects the node’s input data to contain a binary file ‘data’, but none was found [item 1]
As the error specifies, the last node just before ‘LinkedIn’ must output a binary file with field name ‘data’ for the operation to return success. Here is an example of a binary file:
