instance offline and won’t restart
Hey @Ze_Governo, are you using an n8n.cloud instance? I had a quick look but into this but seems there is no n8n.cloud account associated with your forum email.
Could you raise a support request via n8n.cloud’s help center (at the bottom you’ll find a Contact support form)? This will help us identify the right n8n.cloud account and look into this.
