In the last community meeting I mentioned about integrating schemas in the data management of n8n as an experiment. The case scenario is for compliance and data usage transparency.
Without getting into details right now, would it be theoretically possible to:
- Have an interface UI (unclear if separated or as part of the modules themselves) that allows for configuring a given schema to a result set (say JSON for the purpose of this scenario)?
- Allow using the resulting data structure using the field names in the schema
- Generate an extra output from the nodes that logs all usage made in each of them
Let’s leave it at that for the time being.
Thoughts?
