Does anyone have experience in using UI Vision RPA? it has command line API so I was able to successfully launch the macro in n8n using the Execute Command Node but I don’t know how to exactly make it wait for the macro to finish before n8n moves on to the next node. Right now the workflow is processing all the nodes without waiting for the browser macro to finish.
- **n8n version:1.89.2
- **Database (default: SQLite):default
- **n8n EXECUTIONS_PROCESS setting (default: own, main):default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):npm
- **Operating system:Windows Server 2022
