Invalid form body when using sendAndWait function in discord
I’ve been trying to create an integration between our discord server and custom AI Agent that uses OpenAI resources to generate the response. So far everything’s working fine except sending the message to the discord channel and waiting for the response, whenever I use “send message” option in n8n discord integration, everything seems to be working fine
hello @wontsay
try with {{ JSON.stringify($('AI Agent').item.json.output) }}
Maybe there are some object/arrays in the payload
same problem occurs “Invalid form body”
Can you provide the input data that you are passing to the message field?
I pass the answer returned from OpenAI ChatGPT
