Investigating 100% CPU on n8n Docker Container (v1.99.1)
Hello n8n community,
I’m currently facing an issue.
I’m building and using n8n, started with Docker. n8n Version: 1.99.1 Server: 8 cores CPUs, 16 GB RAM
My workflow is very light. In my Docker Compose file, I’ve set cpus: '4.0', but I’m seeing 100% CPU usage for the Docker container (checked via docker stats), and one of my server’s CPU cores is also at 100%.
How can I avoid this situation?
Any help would be greatly appreciated.
Thank you!
Hey @tuanqn123qn ,
Would you mind sharing your docker-compose and embedding your Workflow please
Jm
Thank you for taking the time to read my topic.
  • Below is the content of my docker-compose.yml file used to deploy n8n:
n8n:
    image: docker.n8n.io/n8nio/n8n
    restart: always
    ports:
      - "127.0.0.1:5678:5678"
    cpus: '4.0'
    labels:
      - traefik.enable=true
      - traefik.http.routers.n8n.rule=Host(<MyHost>)
      - traefik.http.routers.n8n.tls=true
      - traefik.http.routers.n8n.entrypoints=web,websecure
      - traefik.http.routers.n8n.tls.certresolver=mytlschallenge
      - traefik.http.middlewares.n8n.headers.SSLRedirect=true
      - traefik.http.middlewares.n8n.headers.STSSeconds=315360000
      - traefik.http.middlewares.n8n.headers.browserXSSFilter=true
      - traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
      - traefik.http.middlewares.n8n.headers.forceSTSHeader=true
      - traefik.http.middlewares.n8n.headers.SSLHost=<myhost>
      - traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
      - traefik.http.middlewares.n8n.headers.STSPreload=true
      - traefik.http.routers.n8n.middlewares=n8n@docker
    environment:
      - N8N_PORT=5678
      - N8N_SECURE_COOKIE=false
      - NODE_ENV=production
      - WEBHOOK_URL=<MyHost>
      - GENERIC_TIMEZONE=<>
      - EXECUTIONS_DATA_SAVE_ON_ERROR=all
      - EXECUTIONS_DATA_SAVE_ON_SUCCESS=none
      - EXECUTIONS_DATA_SAVE_ON_PROGRESS=true
      - EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS=false
      - EXECUTIONS_DATA_PRUNE=true
      - EXECUTIONS_DATA_MAX_AGE=168
      - EXECUTIONS_DATA_PRUNE_MAX_COUNT=50000
      - QUEUE_MODE=redis
      - QUEUE_REDIS_HOST=redis
      - QUEUE_REDIS_PORT=6379
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      - N8N_PROXY_HOPS=1
      - N8N_RUNNERS_ENABLED=true
      - N8N_RUNNER_THREADS=6
      - QUEUE_WORKERS=6
      - QUEUE_BULL_REDIS_MAX_RETRIES=2
      - QUEUE_HEALTH_CHECK_ACTIVE=true
    volumes:
      - n8n_data:/home/node/.n8n
      - /root/n8n-docker/local-files:/files
    depends_on:
      - redis
    redis:
      image: redis:7
      restart: always
      volumes:
        - redis_data:/data
      command: redis-server --appendonly yes
volumes:
  traefik_data:
    driver: local
  n8n_data:
    driver: local
  redis_data:
    driver: local
If you have any suggestions or improvements, I’d really appreciate your feedback. Thank you once again!
Hey @tuanqn123qn ,
Thanks for posting i believe that yhe high CPU usage is likely caused by the combination of frequent execution (every minute) and multiple resource-intensive operations (3 Gemini API calls + Google Sheets operations)
I’m not sure what can you try can you set it like every 10min once and see if there’s any spike ?
Another thing you can try is give your docker-compose.yml to chatgpt it will refine it for you
Let me know what helps as there are many things to check
Thank mrrobot
My schedule is set to run every 30 minutes.
The Google Sheet node only fetches one record at a time.
Sometimes, even when no workflows are running, the container still consumes 100% CPU.
