Invoice Automation in n8n – extract data from many invoices at once into Google Sheets [Workflow Included]
:waving_hand: Hey n8n Community,
I’ve built a lot of finance workflows over the last few months for friends who run small businesses, and going back through my library I realised I’d never shared the most basic one people keep asking for: a simple batch invoice extractor. So I cleaned one up and pushed it to the n8n template library: Extract batch invoice data from form uploads with easybits and Google Sheets.
The idea is simple. You upload one or many invoices (JPG, PNG, or PDF) through a single form, and it extracts the data from all of them in one go, instead of dragging every invoice in one by one. Each invoice lands as a row in a Google Sheet, and when the batch finishes, the form shows a summary marking every file with a :white_check_mark: or :cross_mark: so you instantly see which ones need a second look.
I also recorded a short video showing how it runs end to end:
How it’s set up:
  • An n8n Form takes one or more invoice files.
  • The files get split into one item per file, keeping the original filename.
  • It loops over the invoices one at a time, sending each to the easybits Extractor, which returns the fields (invoice number, date, vendor, total, and so on) as a structured data object.
  • The filename gets reattached, and a check runs over the critical fields.
  • One row per invoice is appended to Google Sheets, with a pass/fail status.
  • A batch summary is shown as the form’s completion message.
A few things from the build that might save you time on your own flows:
  • The extractor bundles everything you hand it into one request. Pass it all the files at once and you get one merged result back, not one per invoice. Looping one file at a time is what gives you a clean result per invoice. This one cost me a debugging session.
  • Treat “missing” as a signal, not an error. The extractor returns null when a field isn’t on the document. Instead of fighting that, I lean into it: a small check flags any invoice missing a critical field, which is what powers the :white_check_mark:/:cross_mark: summary. Worth catching the sneaky empties too (the string “null”, empty strings, whitespace), so nothing slips through looking present when it isn’t.
  • The fields are yours to change. The mapped fields are just a starting point, so you can add whatever you need to pull from your own invoices, like a VAT ID, PO number, or IBAN. The extractor also has auto-mapping, so you can upload one example invoice, let it detect the fields, and tweak from there.
For more free workflows, feel free to check my GitHub as well:
A star helps other builders find it, so I’d be really thankful for that support.
How do you all handle the invoices that fail extraction? Curious whether people flag them for manual review like this or route them elsewhere.
Have a good start to the week.
Best,
Felix
Extracting messy PDF invoice line items into clean structured spreadsheets is one of the highest ROI automations for small businesses.
We found that adding a checksum comparison on total amounts versus calculated line items flagged corrupted OCR scans before rows got committed to Google Sheets.
Are you handling multi-currency conversion in n8n or letting downstream sheets formulas manage the exchange rates?
