Is anyone can help and direct me where to find console-node? I try to make a simple workflow with start-set-console
“errorMessage”: “Invalid credentials (Failure)”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.76.1 (Cloud)”,
“stackTrace”: [
“Error: Invalid credentials (Failure)”,
" at Connection._resTagged (/usr/local/lib/node_modules/n8n/node_modules/imap/lib/Connection.js:1502:11)“,
" at Parser. (/usr/local/lib/node_modules/n8n/node_modules/imap/lib/Connection.js:194:10)”,
" at Parser.emit (node:events:518:28)“,
" at Parser._resTagged (/usr/local/lib/node_modules/n8n/node_modules/imap/lib/Parser.js:175:10)”,
" at Parser._parse (/usr/local/lib/node_modules/n8n/node_modules/imap/lib/Parser.js:139:16)“,
" at Parser._tryread (/usr/local/lib/node_modules/n8n/node_modules/imap/lib/Parser.js:82:15)”,
" at TLSSocket.Parser.cbReadable (/usr/local/lib/node_modules/n8n/node_modules/imap/lib/Parser.js:53:12)“,
" at TLSSocket.emit (node:events:518:28)”,
" at emitReadable
(node:internal/streams/readable:834:12)“,
" at processTicksAndRejections (node:internal/process/task_queues:81:21)”
i need to connect to console node, but can’t find it in node collaction. can anyone help?
Welcome to the community @2024s !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
If by “console node” you mean Execute Command node then it is not available on n8n Cloud, only in self-hosted soilution.
