Hi there,
Is it possible to add a custom public n8n node so everyone can use it?
Hi there,
Hey @max1, welcome to the community!
Yes, it is possible to create custom nodes, check this section in our documentation for details: Overview - n8n Documentation
As for publishing and making it available to other n8n users, this would typically be done by creating a custom n8n-nodes-module (this is described a bit later in the docs). These modules can be installed by other n8n users (currently, this is a manual process but will soon be possible through the UI).
Hope this helps!
