Is it possible to fill form and click elements with Browserless Node?
I’ve not been able to get ’ n8n-nodes-puppeteer-extended’ to successfully install, but I can install Browserless with no problem. How do I Click on elements and/or Fill in fields using the Browserless Node?
When you need to run code like https://www.browserless.io/blog/2022/04/29/puppeteer-pdf-generator/ Is this done in the Browserless Node or the Code Node? I’m not sure where to begin or where to place code like the sample from the browserless link.
  • n8n version:0.211.2
  • Database you’re using: SQLite
  • Running n8n with the execution process [own(default), main]:own
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]:Docker Compose
Hi @Seavia, welcome to the community :tada:
The browserless node is not a standard n8n node but a community node built by @minhlucvan:
I have not tried it out yet, but perhaps you can file an issue in their GitHub repo if you have any trouble or questions around this node? I am not sure if they regularly check the n8n forum, so GH might be the better channel for questions.
