Hello,
Let’s say we have execution running for 15 min and If I set Timeout After 4 min this means that workflow execution gets cancelled.
If this is the case could you advise is it possible to get notified of workflow execution cancelation when it timeouts? for ex dm to Slack
Thank you in advance!
n8n
2
- n8n version:
- Database (default: SQLite):
- Operating system:
Hello @Tomas_Vaitkevicius
Have you tried to set the error workflow in the workflow settings?
system
Closed
4
