Is possible to restore projects made in my other account?
I made a mistake when I create my account and now I can´t access.
I put a wrong email, and all was save on my browser cache, but I reset my laptop and I realize that I cant access to my account.
I am worried about someone with correct mail access to my workflows with my credentials. Also, I am worried about I can’t deactivate my workflows.
By the way, my other account has my full name to validate I also own that account
Was this an n8n cloud instance or self hosted? The best way is to log into the account, download your workflows, and import them into your new instance.
Thank you for answer @rbreen
It is an n8n cloud instance.
I don’t remember email that I register, I just know my password and my username, I accidentally put a wrong email when I created the account, but I did not realize until now.
I can’t restore password, because I can’t access to that mail.
I am worry about the email exist and someone can access to my account by restoring password.
Do you know if is possible to talk with someone at n8n support?
Here’s a support email. [email protected]
Although, if someone was trying to reset the password, they would need access to your email box and would need to know the name of your instance.
if this post helps solve your issue, please mark it as the solution so others can benefit from it
Thank you! I’ve already sent an email to the address you provided.
I’ll keep an eye out for their response and let you know if they’re able to help.
No problem. If this does solve your issue, please make sure to mark an answer as the solution so others can benifit from it.
