This is a theoretical question, not specific to one workflow.
N8N seems to have one heck of a hard time maintaining data flow from beginning to end.
The rules are surprisingly unique to n8n’s architecture, with the AI informing me that I need one or more of these patterns:
“paired data sets” (15 nodes ago I had an odd result but 25 nodes ago I had an even result and now N8N can’t move my data forward), and/or
“execute once” but also “always return data”, and/or
“execute for each” but also NOT “always return data”, and/or
Use set nodes to re-establish data alivenessness as data will fade and we want to keep it alive, and/or
Use code nodes to re-animate data that appears to have had a near-death experience, and/or
no no no output from airtable will process all the way through to the end but ONLY on Tuesdays and/or
Huh. It worked for me.
This is time consuming and headache inducing. AI tells me I am “right” to be frustrated and the community agrees that rules seem strange and hard to follow.
Is there an instruction book on how to get data through the process without losing it to architecture-based rules?
All I want to do is "for i=0; i< value; i++), or “for each record in this dataset, perform these functions.”
But I am stopped at seemingly every turn when 16 records from Airtable becomes one null record for reasons that 4 hours of AI conversation can’t resolve.
I’m not asking for an answer to THIS SPECIFIC scenario.
I’m asking: What are the rules for dataset integrity?
I don’t believe there is a step-by-step guide on how to “maintain data flow from beginning to end.” The rules are unique to n8n’s architecture, but the same can be said about pretty much any other product. One could even argue this is the reason there is more than one of each type of product—somebody once sat down and thought, “Welp, I bet I can do it better.” Is it always better? Well, I guess it depends on who you ask. Convenience, usefulness, and effectiveness of a product are rather subjective things and differ for people coming from different backgrounds and levels of experience.
I understand you are not asking for an answer to any specific question/scenario, but if you ask me, going through such scenarios and understanding how to deal with them is exactly what brings closure, understanding, and eventually takes the headache away.
If you do want to chat about any specific situation, this forum is a great tool.
Have you ever run into a case where you were advised that the data was not “paired” properly? If I could access the AI chat I had last night I would be more specific. But that was the gist of it. I was getting an error for lack of pairing.
It is certainly a start. I need to create a chain of ownership for new items, rather than just do what I did 30 years ago, you know, declare a variable, and then use it. If you’ll forgive the digression, I’d love to hear your opinions on why this has an advantage over other solutions.
