Is there a gpt or knowledge base that understands n8n and how outputs need to be structured?
I find I can do really cool stuff using claude and chat gpt. however I am constantly battling them to get the correct structure of json or strings etc that n8n needs.
They often don’t understand the format needed even when sending them the error codes. I’m still learning as well so I don’t know what the error is and find myself locked in situations where I’m stuck trying to do the most basic things.
There are GPT’s for other platforms like GHL which are really useful. anyone know of a GPT that can code n8n style?
otherwise is there a standard request I can add to make sure the output is going to function?
Hello, depending where you are currently in your learning journey you might want to take a look on the official N8N tutorials. To understand basic and and more advanced stuff :slight_smile:
