Is there a way in n8n to pass a value to a specific Excel cell without using ExcelJS?
@Borelli theres no native node that targets a specific cell like B5, the Excel 365 node and the spreadsheet file nodes are all row/table based so cell-addressing just isnt a built-in operation. but you can skip exceljs, if the workbook lives in onedrive/sharepoint you point an HTTP Request node at the graph range endpoint (…/worksheets(‘Sheet1’)/range(address=‘B5’), PATCH with {“values”:[[“yourvalue”]]}) and set auth to predefined credential type so theres zero code. is your file in onedrive/sharepoint, or a local file moving through the workflow as binary?
Hi @Borelli
To update a specific cell without ExcelJS, the best method is to use the HTTP Request node to call the Microsoft Graph API directly.
How to use this:
- Copy the JSON block above.
- Open your n8n workflow and Paste (
Ctrl+VorCmd+V) it directly onto the canvas. - Configure the “Configure Excel Cell” node:
- Replace
YOUR_FILE_ID_HEREwith your actual Excel File ID. - Update the
sheetName(e.g., “Sheet1”) andcellAddress(e.g., “B5”).
- Replace
- Configure the “Update Specific Cell” node:
- Click on the node and select your existing Microsoft Excel OAuth2 API credentials from the dropdown.
- Run the workflow.
