Is there a way to run workflows between different N8N servers?
I have N8N running on two different servers. Is there a way to call workflow to execute from one N8N instance to another? If I set up workflows on the same server and I use workflow ID to execute then everything works. But if I try to use URL to call workflow to execute on same or a different server then I get message Unauthorized.
After running Workflow A I get message Unauthorized.
Workflow A on N8N Server 1
Workflow B on different server 2
After running workflow A I simply expect to get JSON return
 "test": "test"
Hey @Tom_M,
The run from URL option is used to read a workflow file from a link and run it on the local n8n instance, The best I can think of what you are trying to do would be to start the workflow on the remote server with a webhook then you can use an http request node to trigger it.
