I have not set this up because I don’t know if it is even possible.
I am using AI image/video generators through HTTP requests. Some of them offer a webhook to signal when the task is done.
Is there any way to have a webhook sitting in the middle of your flow, that will pick up data from the initial part of the flow.
e.g.
Edit Fields ==> HTTP request ==> Wait for Webhook ==> use response and Variables set in Edit Fields to carry on.
I did try a little test, but I can’t have the test webhook listening AND be able to trigger the other part manually.
Would I need to perhaps store data elsewhere in-between. e.g. AirTable or Sheets or something?
- n8n version:
- Database (default: SQLite):
- Operating system:
