Issue labeling in gitea via n8n
I want to create work in n8n for gitea when i have created issue in gitea the issue number which got created get assigned as label to created issue. i have taken webhooknode from which i am receiving json output for created issue from another set node i have extracted that outout as number howeevr in next https node am unable to assign that output as label. error is n8n-nodes-base.httpRequest
Node version
4.2 (Latest)
n8n version
1.83.2 (Self Hosted)
Time
09/04/2025, 14:10:35
Stack trace
NodeOperationError: JSON parameter needs to be valid JSON at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/HttpRequest/V3/HttpRequestV3.node.js:207:39) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:681:50) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:913:62 at processTicksAndRejections (node:internal/process/task_queues:95:5) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1246:20
```want to assign this output
"label":
"100"
] as label= issue-100
hello @_Manasi_Mahindrakar
The issue is saying that your payload is not correct JSON. Can you provide the input data you are trying to pass to the node?
