Issue On Ticket Created Hubspot Trigger
Hi everyone! I new in n8n and I have an Issue trying to use the Hubspot Trigger Event On Ticket Created, I tried On contact created and it works, but when listening to tickets I cant get it work, could you help me?
I put the developer API key, the App Id, the Client Id and Client Secret
I added the Hubspot required scopes for n8n:
When I create a ticket I get a Bad request error, because I don’t have permissions to listen ticket creation
But when I add the tickets scope to the App:
I get the following error trying to reconnect my app with the new scopes:
Thanks in advance
  • n8n version: 1.75.2
hey @LuisM
Welcome to the community! We have a hubspot node auth docs here: HubSpot credentials | n8n Docs
which contains a link for instructions on setting scopes. I think you’re missing a few write permission for certain scopes. Can you double check your configs on this?
Hope this helps!
@LuisM I’ve got the exact same issue. Did you figure out on how to trigger the workflow on a new ticket from HubSpot? Other triggers seem to work (i.e. creating a contact).
Same problem here. I’m trying to get a new ticket trigger… same error as @LuisM
