Hi Community,
I’m building a ticket management system in n8n with the following workflow:
- Trigger: Email IMAP node checks for incoming emails.
- Parse: Extracts relevant fields from the email (including ticket number in subject/body).
- Check in DynamoDB:
- If ticket number exists, update the existing entry with the new/updated message body.
- If ticket number does not exist, insert a new row with all relevant details.
- Send Acknowledgment Email to the user confirming ticket creation or update.
- The message body is not just plain text — it’s a structured object containing:
fromEmail
toEmail
timestamp
emailSubject
emailBody
(and optionally) attachments metadata
Everything works fine except when trying to store this message body in DynamoDB as a Map.
The workflow fails or DynamoDB does not store the field as expected, despite multiple attempts to format the value as a Map.
I’ve tried different JSON formatting, Set node, and manual {{ JSON.parse() }} conversions, but Dynamo still stores it as a string or fails entirely.
Question:
How can I correctly store the email’s message body (with its structured fields) as a Map in DynamoDB via n8n?
Unable to store params of msg body in map format so that can be retrieved easily at frontend.
"ticketId": "TICKET-1234556788965-1233",
"Msgbody": {
"Subject": "Testing new workflows nice",
"From": "<[email protected]>",
"To": "<[email protected]>",
"Msg": "<Testing new workflows nice... message body> ",
"Timestampe": "Mon, 4 Aug 2025 05:57:51 +0000",
"Msg-type": "Email",
"Email-status": "Default"
- n8n version: 1.105.3
- Database (default: SQLite): AWS Dynamo DB
- n8n EXECUTIONS_PROCESS setting (default: own, main) : default
- Running n8n via (Docker, npm, n8n cloud, desktop app) : Self Hosted.
- Operating system : Linux
